Alright an extremely weird question... But is it possible to use console hardware like PS4/PS5 to use as GPUs to assist rendering?
Solved by jaslion,
So firstly the os is so locked down this isnt happening.
Secondly we have the xbox one/ps4 cpu/apu combo purchasable from ali express and they are weak. Also due to being amd you have almost no gpu accelerarion possibilities. As in even lets takes a older blender that has nvidia rt and amd opencl. A single rtx 2060 is well over 10x faster than even multiple vega 64's rendering togheter.
Making a gpu inst a simple task either. You need a lot of people to develop it and make drivers to make it function.
Simply put its literally impossible
Just sell the ps4 and get a gpu for 200$ even less a rtx 2060 is available and king for compute tasks at that price
