But will it fit in? HAF XM
Solved by WhatTheQuack,
Yes! (to your title question)
The motherboard (and maybe the graphics card and CPU heatsink) is the only thing that you have to worry about in terms of case compatibility. The motherboard that you have chosen is ATX, and the case is also ATX so it will fit just fine.
As for the cooling components, that Noctua heatsink is a great option! (And will fit in this case) The Bitfenix Spectre fan is slightly inferior to the Spectre Pro variant, but it is cheaper.
Hope this helps!
