Directional RF Chamber for 5.8Ghz receivers
Hi guys!
After watching LTT's RF chamber video I had an idea for a project.
I'm one of the organizers and race directors in the Polish FPV micro drone racing league and I've been struggling with our lap timer solution for quite some time.
To quickly describe our setup:
Our laptimer (the device that measures our lap times) is based on multiple RX5808 5.8Ghz receivers. Each receiver is set up to a specific channel and when multiple drones are racing, it gets the RSSI data from all of them and looks for signal peaks. Laptimer is set up next to our start gate and when a drone flies through the gate, laptimer catches that.
The problem with the system is that often (especially on smaller tracks) drones will fly behind the laptimer or even above the laptimer and will get picked up. We managed to limit the issue by putting the lap timer inside of a metal ammo box and directing the open side of the box towards the start gate. It works much better, but it's still not great. When a drone files behind the ammo box, the signal peaks. The peak is lower than when the drone is in front of the box, but it's still high enough that it makes marshalling races very fiddly.
I'm determined to make a better solution, but I'm not sure what the best way would be. I know from our community that some people made enclosures using copper mesh and even with grounding the mesh, the situation is still not great.
I've seen in the LTT video how fiddly the process of eliminating RF is and I'm pretty sure we're making some dumb mistakes in our enclosures
Any help will be greatly appreciated!
Try, fail, learn, repeat...
Would putting aluminum foil around the box and/or on the inside of the box except for the opening help?
My PC Specs: (expand to view)
Main Gaming Machine
CPU: Intel Core i7-10700K - OC to 5 GHz All Cores
CPU Cooler: Corsair iCUE H115i RGB Pro XT (Front Mounted AIO)
Motherboard: Asus TUF GAMING Z490-PLUS (WI-FI)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600
Storage: Intel 665p 1 TB M.2-2280 NVME SSD (x2)
Video Card: Zotac RTX 3070 8 GB GAMING Twin Edge OC
Power Supply: Corsair RM850 850W
Case: Corsair 4000D Airflow
Case Fan 120mm: Noctua F12 PWM 54.97 CFM 120 mm (x1)
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x4)
Monitor Main: Asus VG278QR 27.0" 1920x1080 165 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
Server/Future NAS PC
CPU: Intel Core i5-12400
CPU Cooler: ID-COOLING SE-224-XTS
Motherboard: MSI PRO B760M-P DDR4
Memory: TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR4-3200
Storage: Crucial P3 Plus 1 TB M.2-2280 NVME SSD (probably will pick up a WD Red drive or two eventually)
Video Card: N/A - May throw a GPU in eventually though.
Case: Cooler Master MasterBox Q300L
Power Supply: SeaSonic FOCUS Plus Platinum 750W
Case Fan: ARCTIC P12 PST 56.3 CFM 120 mm (x5)
Peripherals
SteelSeries Rival 600 Wired - SteelSeries Apex 5 (Hybrid Blue Switch) - SteelSeries Arctis 9X - Mackie CR3-X 3 Inch Speakers Pair - APC 1500VA UPS
I assume that copper mesh works better than aluminum since copper is much more conductive so it would probably make a small difference, but not enough to actually fix the issue.
Are you using a directional antenna /  What kind of antenna are you using?
“Look at you soaring through the air majestically... like an eagle. Piloting a blimp.” - GLaDOS
That actually sounds like a job for a directional antenna like a horn antenna. I have, for example some microwave experimentation sets for schools that work at a little over 4GHz and those have horn antennas, so they should also work at a little higher frequencies. Really funny is, that these sets were actually made in Poland...
