Need help for my upgrade.
Go to solution Solved by 191x7,
32 minutes ago, ferdK said:
I have 16gb 3600mhz RAM, Asus PRIME B550-PLUS motherboard and 800W CoolerMaster 80 Gold. CPU is R5 5600x and GPU is RX 5700XT.
1st - you need more RAM.
2nd - the 5700X or 5800X is not a decent upgrade over the 5600X, at least not for gaming.
3rd - the 5700XT is about equivalent to a 6600XT or a 6700 non-XT or an nVidia RTX 2070 Super, going with a 3070 is no upgrade.
4th - The 5600X/5700X/5800X paired with a 6800 would perform like a 5800X3D with a 3070 because the nVidia cards require a more robust CPU to drive them properly.
5th - You haven't mentioned your use resolution. If it's 1080p, get the 5800X3D in any case, but don't upgrade the GPU over a 6700XT, 6750XT, or 6800. Don't get an Nvidia because anything that would be noticeably (nicely) stronger than the 5700XT would be bottlenecked even with the 5800X3D. If the resolution is 1440p, you have more options. Like a 6950XT or 6800XT, without upgrading the CPU, you'd get a nice boost in a couple of years when you upgrade the platform. Or get the 5800X3D and pair it with an RX 6800...
Budget (including currency): $700
Country: USA
Games, programs or workloads that it will be used for: Emulating (Switch, PS3 mostly), Competitive FPS, AAA games.
Hello, I'm planning to upgrade both my CPU and GPU. I need help because I'm considering two options at this time: Ryzen 7 5800x3D+RTX 3070 or Ryzen 7 5800x+RX 6800.
I am wondering which one of these upgrades will get me the most FPS, they're about the same budget. I know the 3D v-cache is king in gaming, but I've seen benchmarks where it is about 15% faster than the 5800x with the same GPU. But I wanna know if the 5800x w/ RX 6800 would perform better than 5800x3D w/ RTX 3070.
I appreciate you taking the time to read and comment, thanks for the help in advance!
Country: USA
Technically AMD gets you the better FPS. NVIDIA is better for stability and longevity, while also getting you great FPS.
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
Whats your full spec? 5800X3D can be brutal to the board VRM.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
Self Introduction and Current Rig
Hi, have you seen Hoshino Ai recently? Shes not missing, i just thought you should search her on the Internet.
Thanks a lot, I know AMD also gets better with time and there are also a community for custom drivers and such. Thanks so much for the help.
  • Main PC: AMD Ryzen 9 5900X - EK AIO 360 D-RGB - Arctic Cooling MX-4 - Asus Prime X570-P - 4x8GB DDR4 3200 HyperX Fury CL16 - Sapphire AMD Radeon 6950XT Nitro+ - 1TB Kingston Fury Renegade - 1TB ADATA SX 6000pro  - 512GB ADATA SU800 - 1TB Seagate Momentus 5400rpm 2.5" - Seasonic PX-850 850W  - custom black ATX and EPS cables - Fractal Design Define R5 Blackout - Windows 11 x64 2022 - 3 Arctic Cooling P14 PWM PST - 5 Arctic Cooling P12 PWM PST
  • Peripherals: LG 32GK650F - Philips 226VL - Logitech G Pro X Superlight with Tiger Ice - White Shark Spartan X (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Laptop: Acer E5–575G-386R 15.6" 1080p (i3 6100U + 2x4GB DDR4 + GeForce 940MX + 256GB nVME) Win 10 Pro x64 22H2 - Logitech G305 + AAA Lithium battery
  • Networking: Asus RT-N18U - SpeedPort Plus - 35/7 Mbps vDSL - TP-Link TL-WA850RE - TP-Link 5-port 1Gbps switch
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Streaming/Server/Storage PC: AMD Ryzen 5 3600 - LC-Power LC-CC-120 - MSI B450 Tomahawk Max - 2x4GB ADATA 2666 DDR4 - 120GB Kingston V300 - Toshiba DT01ACA100 1TB - Toshiba DT01ACA200 2TB - 2x WD Green 2TB - Sapphire Pulse AMD Radeon RX 5700XT - 550W EVGA G3 SuperNova - Chieftec Giga DF-01B - Logitech G710+ - Roccat Kone Pure Military Desert strike - Logitech S-220
