High GPU Temps whilst gaming and possible wrong fan config
xKuwa
Hey all,
Currently have a PNY RTX 4090 and a 13700K build inside the Phanteks Enthoo Evolv X and had a couple of questions regarding my temps and fan config. I've noticed when playing games my 4090 will reach temps anywhere between 65c and 75c pretty quickly and was wondering if this was a potential issue with my setup or if I'm worrying for nothing. Also is my fan config currently efficient for my build or should I be switching them around?
Fans inside the case are the Lian-Li SL INFINITY Fans, all are 120s apart from the rear fan. Also, my monitor is a 3440x1440 Ultrawide.
15 minutes ago, xKuwa said:
Hey all,
Nice rig!
Your temps are fine 😉
System : AMD R9  7950X3D CPU/ Asus ROG STRIX X670E-E board/ 2x32GB G-Skill Trident Z Neo 6000CL30 RAM ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Thermalright Peerless Assassin 120 cooler (with 2xArctic P12 Max fans) /  2TB WD SN850 NVme + 2TB Crucial T500  NVme  + 4TB Toshiba X300 HDD / Corsair RM850x PSU
Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
40 minutes ago, PDifolco said:
Nice rig!
Is the fan config fine? and the fact my GPU will rise to those temps within a short amount of time isn't an issue? I am running literally everything max in Cyberpunk with the new RT tech and using over 13GB of VRAM, so I guess those temps are to be expected, still makes me uncomfortable though.
Sounds good, front intake top and back exhaust
GPU are supposed to reach 65 to 75C under full load
I wouldn’t worry about how fast the gpu warms up. Just what temp it warms up to and stays at. 75c is perfectly fine and it’s what my Zotac liked to sit at when it still had its air cooler.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
