High Ambient temperature and Cooling
Solved by thrasher_565,
4 hours ago, abbatrombone said:The cost tends to be higher which im not a fan of but your computer overheating can be costly as well is why im asking.
the pc will thermal throttle so no harm done to it. but a prorper water cooling loop can cost like $1000... so... it would be lower temps but it also will dump even more heat in to the room... making it even hotter... witch would reduce how mush cooler it would be...
for that $1000 you could just replace something when it die's is the point in making.
