Need help in choosing PC Parts
27 minutes ago, pasposty said:I really want WIFI and i don't know if i have to take a WIFI dongle or a built in WIFI
Im definitely in the former, as theyre far more transferrable from a build to another and thus opening you to good non-wifi board options.
And of course i threw in a pretty significant cost compression without compromising performance nor upgradability to 5800X3D which would still be very good CPU for a while.
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor ($156.01 @ Amazon)
Motherboard: ASRock B550M Pro4 Micro ATX AM4 Motherboard ($106.99 @ Amazon)
Memory: ADATA XPG Z1 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory ($36.99 @ Amazon)
Storage: Mushkin Pilot-E 2 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive ($109.99 @ Amazon)
Video Card: ASRock Challenger D OC Radeon RX 6700 XT 12 GB Video Card ($344.99 @ Newegg)
Case: Fractal Design Focus 2 RGB ATX Mid Tower Case ($66.98 @ Newegg)
Power Supply: Corsair RM750e 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($99.99 @ Amazon)
Wireless Network Adapter: Gigabyte GC-WBAX210 802.11a/b/g/n/ac/ax PCIe x1 Wi-Fi Adapter ($46.99 @ Amazon)
Total: $968.93
Generated by PCPartPicker 2023-03-26 08:10 EDT-0400
6750XT is just a refresh of the 6700XT with overclocks built in. You better off going with Used 6800XT or just overclocking a 6700XT instead. My opinion on RAM overclock is pretty much just "run XMP or XMP with more voltage", so i throw in a pretty standard 2x8 3200C16 kit, the old fashioned.
