What Ryzen 5000 cpu to go for?
2 minutes ago, Datrat said:I edited the list link, but its an EVGA RTX 2080 XC. I was hoping to spend less money to get a temp fix, but I do know that it doesn't make sense long-term. I was hoping to keep my 32gb of ram longer so I would lean Intel 13th gen, but that requires a lot more of an investment, and I don't really want to stay ITX.
If you're strapped for cash, but your current system can't do what you need it to do, then you can just go with the Ryzen 5 5600. You honestly won't lose that much performance vs the 5700X and it'll save you $50. The 3400G is going for $70+ on eBay, so you can recoup half of the money it costs to get the 5600.
Then you can start saving up for a more substantial upgrade. Given the level of competition in the CPU space right now, I fully expect 14th gen vs 8000 series to give us another 15-30% jump in performance, which will give you the option of getting something even more substantial if you can afford it, or you can probably pick up a used 7000 series chip for cheap when people start upgrading.
