DDR4-4400 is extremely overclocked and hardly cheap either, and compatibility will be a nightmare.
Ram is often not fast enough. We often see improvement with faster ram compared to slower. This is in part why AMD X3D CPUs help out, because they work around the ram being not fast enough.
ddr4 4400 cl16 is bdie, youd problably have to push it to max volt before needing maxmem (~1.75v) to get it there and youd still need to sacrifice far more important subtimings like trfc, volt isnt an issue but cooling and price definitely is. and what imc can run 4400 bdie in gear 1 unless its a golden imc.
Outspeeding gear 2 penalty is just impractical unless you got some top bin hynix djrs running 5600+ 1.9v or something so dual rank at 4200 in gear 1 is pretty much the best you can do ddr4 wise
also its just plain stupid to focus on tightening cl when basically all the subtimings give a much more substantial performance impact and dont gobble a crapton of voltage (aside from trfc or tcwl if you tighten them enough), cl is just for flexing or benching purposes when everything else is maxed out
I see almost no one on this forum obsessing about that.
2 hours ago, 8tg said:
t really wasnt until ddr4 that people started to notice or care about qualities of ram
That’s not true at all 🙂
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
All good my man! Things might have been like that in your circle, but in my circle it has always mattered, for me I have been paying attention to speeds and timings since the SDR days 😄
If you are an average Joe, it wont matter much to you.
