RAM, 3200mhz cl16 vs 3600mhz cl18?
Solved by RONOTHAN##,
6 minutes ago, JimmyHackers said:currently 16gb (2x8gb) of crucial 2400mhz cl16 ram.
Odds are you can just overclock this to 3200 CL16 very easily by just bumping the voltage to 1.35V, so unless you're going for a higher capacity kit that's what I'd do first. Just raise the voltage, set the frequency to 3200, and the timings to 16-18-18-38 and you should be good to go.
If that doesn't work, get the 3600 rated kit. Theoretical latency should be basically the same, but the memory controller is clocked higher so the 3600 kit should get a slight theoretical latency advantage as well as a bandwidth advantage since it's clocked higher. The 8700K has a good enough memory controller that 3600 is pretty reliable to work.
