Hey all, I'm having a really difficult time keeping this 13900K Cool.
I have it in an ASUS Z790-E Strix board, hardly entry level, paired with a Corsair H150I, with the fans running on blast all the time, as well as a thermalright bracket. The case doesn't even have side panels on it.
Right now I have the CPU de-clocked so it doesn't constantly thermal throttle.
The way I see it - I have two options left:
Replace my Corsair H150I with the 420mm Corsair H170I Elite Capellix, or do a custom loop.
I'm a bit weary of doing a custom loop, because I've never done one before, but I am confident I can do it if tasked. The question is - Is custom looping going to be significantly better than the H170I to the point where I can almost OC the 13900K?
https://linustechtips.com/topic/1483391-to-custom-loop-or-not-to-custom-loop/
IF you have the money and time and like the astetics you could do a custom loop. And the Perfomance of a Custom loop entirely depends on the components you choose and your skill. 🙂
Money and time are not a concern. Temperature and performance are 😛 So it sounds like I should do a custom loop?
From Jayz 2 CEnts review of the cooler that you mentioned it is running at 70* C on a 1700 socket iam assuming 12900K so you have the head room with that but custom loop will give you more overclocking headroom so
always a nice place to be
a custom loop will absolutely be the best way to keep temps under control.
I'd recommend using a LianLi O11 with a distribution plate/pump/res combo, EKWB cpu block, and definitely consider adding the GPU to the loop. I would be use BeQuiet or Noctua fans in pull configuration. I like the black low maintenance tubing with brass colored fittings.
Always do a loop. No reason to be a pleb and just get by when its so easy and fun to do.
Thanks for your feedback - I have a few follow up questions. I think you convinced me to pull the trigger my guy!
Question 1: I have these fans lying around somewhere, are they pretty good? Or should I I get nicer ones? I really like the ones that are daisy-chainable.image.png.018f44671e41ca2a3999aa06054645c7.png
Question 2: Do I get a fan controllers?
Question 3: How many rads with that Lian Li Case?
Question 4: If I go hard tubing, does EK make quick disonnects or no? Is swapping out MOBO's and GPU's pretty easy once you get everything together? Just replace a few parts and you're good to go?
Thanks for all your help on this one!
hard line is not meant for easy swap out of parts. each time you add something new you most likely need to rebend tubing. so qdc are not used for hardline.
i guess you could do a hybid and use some hardline and some soft tube from gpu and cpu. thow the idea of hardline is to build it so most of the liquid gose all out the drain valve at least should be easier then soft tubing.
ek makes the best qdc but cost a $$$$$$$$$$$$$$$$$$$$$$
depends on what lian li case you got. but if its the 011 probably top and bottom. i no some lian li case have clearance problems
do take note, custom loop there's a bit more maintenance care needed
  1. nf-p12 & nf-a14 are still ok, the better one will be nf-a12x25
  2. if yer mobo has enough fan header use mobo, i'm using aquacomputer quadro (rad fans rpm base of coolant temp)
  3. o11d can fit up to three 360 rads
  4. AFAIK hard tubing = no QDC ; if u wanna swap parts around soft tubing + qdc is the best way (see my build below)
with rgb
Ryzen 5700x + EK Supremacy D-RGB | 2x8 GB DDR4 Klevv 3200 MT/s | MSI B550M Mortar | Palit 3070 GamingPro LHR + Bykski N-PT3070PRO-X | Corsair RM750 | Alphacool EPDM + QDC | Aquacomputer Quadro + HighFlow2 | EK D5 XTOP | Freezemod 360 30mm rad + Barrow Dabel-20b 360 20mm | Barrow & Freezemod fittings | Corsair 5000D Airflow
Audio: beyerdynamic DT 900 Pro X + iFi ZEN Air DAC + Razer Seiren Mini
16 hours ago, fonzz1e said:
  Reveal hidden contents
with rgb
  Hide contents
i would make the back intake imo
front & side already intake 😅
oh my bad haha
+1...Soft tubes for now since it would be your first. Hard lines are for when you get good at doing soft lines and have some experience and you want to make a very clean show piece. They are a pain to deal with if you are a parts swapper or if a issue crops up and you need to rma a part etc.... then you got to clean, leak check, refill, bleed again. They are alot of work but will give you great temps with alot of leeway to mix and match parts of much higher quality. I cant believe your AIO unit is a 360 and its having such trouble. Im sure youve done the troubleshooting, but you never said what your idle/max temp numbers were?
i didn't get to that part as the buble was stuck in the cpu block... but anyway i hope ill fix it haha has now i have a nuts loop of 5x 560 rads... wish me
luck
i have seen people do a first build with hardline and it looked good so just depends on the person i guess..
