Running a GPU at full speed with 16x slot with 4x bandwidth at gen 2 speeds
On 1/9/2023 at 11:24 PM, LeonPlayz said:I've got a Dell Vostro 270 motherboard which has one PCI-e 3.0 x16 slot which I put my GTX 660 OEM 1.5gb into so it has full bandwidth. Recently, I bought a different motherboard the Intel DQ77MK which has a PCI-e x16 slot, but it runs at x4 speed gen 2.0. If I put my GPU in that slot it would obviously severely decrease its performance due to the bandwidth being limited. But the board also has on-board discrete graphics which runs at x16 Gen 3.0 speeds but it requires a CPU with an iGPU, I have a Xeon E3-1230 V2 so I don't have one. But, would it be possibly to put the GPU into the x16 slot, but instead of letting it run at x4 gen 2 speeds, I bypass it and use the pcie lanes dedicated to the discrete graphics to get the full bandwidth of a x16 gen 3 slot, even though I'm using a x16 slot at gen 2 x4 speed.
Current motherboard: Dell Vostro 270
New motherboard: Intel DQ77MK
GPU: GTX 660 OEM 1.5gbCPU: Xeon E3-1230 V2
RAM: 2x8gb 1600mhz
Update: I have just received the motherboard and it has two x16 style slots but one of them is an x4 slot but has a cutout on the side of the pci E x4 slot to make it a x16 slot. All the bandwidth works now.
