Looking for small case with good airflow, Fractal Design Torrent Compact White TG ?
5 minutes ago, Mark Kaine said:i see. i got confused because the store page im looking at says "E-ATX motherboard", other descriptions said ATX, m-ATX... at this point im just trying to make sure my motherboard even fits (b550m mortar wifi, so m-ATX)
And yeah it does look easy to build and has the perfect dimensions for me.
yeah, well that's not a given per say, my inwin doesn't remove the top and has the psu on top too (huge reason its so difficult to build in... you basically cannot access the cables from the psu. at all. i don't know what they where thinking!
But alright, thanks for all the info, and you think my motherboard (m-ATX) should fit? i mean it would be stupid if not (e-ATX, never heard of that, the store description is really awful haha)
they often list the biggest board that will fit meaning anything smaller will work as well.
yes your m-ATX board will fit.
e-ATX boards have 1/2 inches of extra space on the right side to accommodate additional hardware, often used in servers.
