WIFI upgrade advice
WildW_UK
 I'm looking for some advice on what to buy to improve our slow and weak WIFI. I'm in the UK where the most common setup is a cheap combined modem/router provided free by the internet service provider, and ours provides a spotty and barely usable experience throughout the house. We have a couple of desktop PCs upstairs that are connected through TP-Link homeplug adapters, which mostly work but drop out for minutes at a time every now and then. We rent so we can't run any ethernet cables upstairs or through walls. I'm hoping that some more modern WIFI kit will make things better.
Whatever I get - WIFI router or access point I guess - will need to handle two gaming PCs and mutliple TVs streaming stuff. I see lots of choices at lots of different price points, and I don't know how much it is worth spending. Because we have desktops with no existing WIFI I'll also need adapters for those. . . is it worthwhile to go for PCIe cards with more significant antennas, or are USB WIFI dongles up to the task?
You absolutely want dedicated wifi cards for your PC. USB ones wont cut it. I've got one of these and its great: https://www.amazon.com/dp/B0B4VH4G1C?psc=1&ref=ppx_yo2ov_dt_b_product_details you could go with a cheaper Wifi 6 one.
I personally recommend the Linksys Velop AX4200: https://www.linksys.com/gb/tri-band-ax4200-mesh-wifi-6-router/MX4200-UK.html
Heres a review: https://www.tomsguide.com/reviews/linksys-velop-ax4200
Great wifi 6 router with a nice companion app. Try just one out and see if you need a second to cover your home.
Laptop: 2019 16" MacBook Pro i7, 512GB, 5300M 4GB, 16GB DDR4 | Phone: iPhone 13 Pro Max 128GB | Wearables: Apple Watch SE | Car: 2007 Ford Taurus SE | CPU: R7 5700X | Mobo: ASRock B450M Pro4 | RAM: 32GB 3200 | GPU: ASRock RX 5700 8GB | Case: Apple PowerMac G5 | OS: Win 11 | Storage: 1TB Crucial P3 NVME SSD, 1TB PNY CS900, & 4TB WD Blue HDD | PSU: Be Quiet! Pure Power 11 600W | Display: LG 27GL83A-B 1440p @ 144Hz, Dell S2719DGF 1440p @144Hz | Cooling: Wraith Prism | Keyboard: G610 Orion Cherry MX Brown | Mouse: G305 | Audio: Audio Technica ATH-M50X & Blue Snowball | Server: 2018 Core i3 Mac mini, 128GB SSD, Intel UHD 630, 16GB DDR4 | Storage: OWC Mercury Elite Pro Quad (6TB WD Blue HDD, 12TB Seagate Barracuda, 1TB Crucial SSD, 2TB Seagate Barracuda HDD)
