is 500 Watts really enough for an RTX 3060 as long as it's a quality psu?
Solved by GorujoCY,
Marking the solution for future potential consumers! I'm getting the RM550x it seems...
However if you are in a tighter budget for some reason, 500 watts should be fine as long as it's a quality PSU and you don't have other power hungry components...
1
2
3
ShayOh ·
Posted in Troubleshooting2 -
Newbietobe5467 ·
Posted in Troubleshooting3
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
