Internet working at 5% of proper speed
Solved by Lurick,
Powerline is notoriously bad for keeping consistent connections especially with multiple powerline devices in the mix.
The powerline adapters you linked are all 10/100Mbps ports, you'll never got more than ~90Mbps in a best case scenario. Anything in the path such as a UPS or surge protector will kill the speed and being on different phases or circuts can cause issues for one computer whereas another can be on a different circuit without issues.
