SSL protocol problems
Go to solution Solved by Jefez,
I tried to search for the error one more time on the web, and one of the pages I encountered told me to delete a file from this directory...
The file was named 'hosts', and then I tried to delete it.
After that, things magically worked again! Somehow...
Thank you for all of those who replied and tried to help 馃槃聽Best of days to you guys
My problem is as the title suggests--though I still don't know if it is actually the problem--specifically that because of it I'm having trouble connecting to services by Rockstar games
Connection from their launcher is sadly also borked
Though when I accessed the address for their support page from my phone (from the same home network), the page loads. So I suspect that it's a problem from my PC, though I don't know where, exactly
Methods I have tried (that I know of) but to no avail:
  • Restarting both router and PC
  • Using a DNS resolver (Cloudflare's 1.1.1.1)
  • Using a VPN
  • Clearing SSL state
  • Resetting my network settings from Windows
  • Uninstalled Windows updates that I thought were interfering
All other webpages work normally with my current connection, only the ones from Rockstar fails to even connect
Any help would be greatly appreciated. Thanks in advance!
In picture: Rockstar Games Launcher (above), Rockstar Games support page from Chrome (below)
https://linustechtips.com/topic/1448577-ssl-protocol-problems/
My memory is ssl was deprecated years ago. 聽It鈥檚 something else now
Not a pro, not even very good. 聽I鈥檓 just old and have time currently. 聽Assuming I know a lot about computers can be a mistake.
https://linustechtips.com/topic/1448577-ssl-protocol-problems/#findComment-15517904
Make sure the date on your router and on your computer is configured correctly.聽
Yeah, bad computer time can cause encryption to fail.聽
If date/time is wrong, one possible reason could be the battery on your motherboard is dead and must be replaced... but that's rare, usually such battery lasts 5-10 years, because while computer is plugged in, the power supply's 5v stand-by powers the circuit instead of the battery.
https://linustechtips.com/topic/1448577-ssl-protocol-problems/#findComment-15517915
Even if youre MB battery dead, windows usually will auto sync the time based on the timezone, this is default, unless you turn it off.
Rockstar actively banned IP address for illegal activity, try the free account from protonvpn, it worked for me in the past.
Ryzen 5700g @ 4.4ghz all cores | Asrock B550M Steel Legend | 3060 | 2x 16gb Micron E 2666 @ 4200mhz cl16 | 500gb WD SN750聽| 12 TB HDD | Deepcool Gammax 400 w/ 2 delta 4000rpm push pull聽| Antec Neo Eco Zen 500w
https://linustechtips.com/topic/1448577-ssl-protocol-problems/#findComment-15517920
You mean TLS. The error code simply still says SSL for backwards compatibility. If you visit the page you can see they're using TLS 1.2 which is recent and should be supported by any modern browser.
Of course it could always be OP is using an old browser that doesn't support TLS 1.2.
https://linustechtips.com/topic/1448577-ssl-protocol-problems/#findComment-15517934
Yes. 聽Tls
https://linustechtips.com/topic/1448577-ssl-protocol-problems/#findComment-15517970
Time & date both on router and computer are all correct to my timezone, and the CMOS battery is still fine, so I don't think the problem's there
Even if so, if it was聽a time & date issue, I shouldn't have the ability to access聽all聽websites, not just Rockstar's
Nope, doesn't work. I also tried that, thinking that my earlier VPN wasn't "VPN-ing" properly, but it's still the same with Proton
If I聽was聽actually banned, wouldn't it be I just become unable to access their games online, rather than banning me entirely even from their support page..?
I am using the newest available version of Chrome, though since it affects Rockstar's Game Launcher too, I suspect it's entirely between their servers and my computer. My phone works fine when I go to their support page
And to add, another methods that I have tried are 1) resetting my network settings in windows, and 2) uninstalled windows updates that I thought might have been the problem
Both are still to no avail, sadly
https://linustechtips.com/topic/1448577-ssl-protocol-problems/#findComment-15518400
First of all what OS are you using? This issue usually happens on old OSes that don't support current SSL.
Second check name resolution of the impacted sites, see if DNS is actually resolving to the correct servers.
Then see if your browser was trying to contact a proxy before connecting to the actual site. Check system and browser proxy settings.
Then find out if there are MITM attacks in IP level, use wireshark to check the TCP then HTTPS handshake process to see exactly what went wrong.
https://linustechtips.com/topic/1448577-ssl-protocol-problems/#findComment-15518573
https://linustechtips.com/topic/1448577-ssl-protocol-problems/#findComment-15519347
If you had SSL errors, and you had to delete the hosts file, then its most likely your computer got infected with some sort of Malware.聽
It probably had static entries redirecting you for a MitM attack, hence the SSL errors.聽
I'd recommend checking your DNS settings to make sure they havent been changed manually either to some unknown DNS server.聽
Make sure this is on Obtain automatically, or if you specified manual DNS, make sure its pointing to the servers you entered
Also click on 'Advanced...' and go to DNS and make sure there arent any servers specified in the first box
I assume you're using Windows built in Microsoft Defender.
I'd strongly recommend scanning your machine with a 3rd party tool as well such as MalwareBytes or Spybot Search & Destroy.聽
To make sure theres no further traces of whatever infected your machine to modify the hosts file.聽
Desktop: Ryzen9 5950X聽| ASUS ROG Crosshair VIII Hero (Wifi)聽| EVGA RTX 3080Ti聽FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU聽| Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G聽Monitor | Roccat Vulcan TKL Pro Keyboard |聽Logitech G Pro X Superlight聽 |聽MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x |聽ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU聽| Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe聽| LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe |聽EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
https://linustechtips.com/topic/1448577-ssl-protocol-problems/#findComment-15519461
