Desk mount clearance
Solved by VIVO-US,
Your typical desk mounted monitor arm will need about 2" or more of depth clearance. A standard clamp with a hand bolt under the desk will typically need about 5" or 6" of available height for the hand bolt to fit, but there are a few stands out there with a low-profile clamp that instead tightens from the top, so one of those may work for your specific desk.
Featured Topics
Artur Hawkwing ·
Posted in Storage Devices1 -
3
ShrimpManVanGogh ·
Posted in Troubleshooting2 -
DudeSquad11 ·
1
Gnoxis7 ·
Posted in Phones and Tablets2 -
2
5
Mr_Roboto ·
Posted in General Discussion3 -
3
