Available power on molex chain for each connector?
13 minutes ago, tkitch said:are you talking about 5 separate PSU Connections, or 1 PSU Connection, or another number?
5 Molex connectors on the same chain, have the limit of a single molex draw, not 5x that.
no, a chain with N molex connectors will be limited by the connector on the power supply in which the chain is inserted. If the power supply connector can do 100 watts, and each molex connector on the chain can do 50-60 watts ... the molex connectors in total can only do 100 watts.
I think he means he uses 5 chains with molex connectors, and connects one OCTO in a single molex connector on each chain.
Assuming 0.3A during regular use, around 0.75A at spin-up (probably too much but nice round number), you have 8 x 0.3 = 2.4A during regular use , 6A during startup.
You're nowhere close the individual molex connector limit (5A) and nowhere close to the chain's limits (9A+)
You could probably have two OCTO per chain, one octo per molex ... only concern is peak current when all 16 fans spin-up.
Though, there's enough thermal mass that the cable will tolerate 12-15A for a few seconds even if each fan peaks at even 1A for a few seconds at spin-up. The ratings of 9A for the psu connector and 5A for the molex are for sustained use, not a short burst value.
In the 2-5 seconds it takes for the fans to spin up, there's not enough time for the contacts in the connectors to heat up, or for the wire to get too hot and so on.
Once they're spinning at 0.3A average current, 16 fans would only consume around 5A or 60 watts, which can be handled by a chain of connectors and it's well within the ratings of all parts involved.
You can go overboard if you want, ideally you'd do a staggered spin-up of the fans ( spin 8 fans, wait 2-3s, spin the next set of 8 fans) ... but I don't know how you'd do it. If the OCTO has an enable pin of some sort, you could implement a delayed star but otherwise it's not easy.
