Difference in brands for SFP+ to RJ45 10Gb Modules
8 hours ago, PenguinMaster said:I have a couple of questions about my ubiquiti setup and about some SFP+ to RJ45 adapters.
Before I answer the rest of your questions I'd like to warn you about 10GBASE-T SFP+ modules.
Those SFPs usually do not follow the SFP+ spec when it comes to power consumption. SFP+ ports are only rated for up to 1.5 watts of power. Meanwhile, those modules you linked can demand up to 2.5 watts of power (in some cases even more). As a result, you might get issues with heat or power if you connect too many of them to the same switch. IF you must use 10GBASE-T modules, it is strongly recommended to not put them next to each other.
Secondly, 10GBASE-T modules have much higher latency than fiber modules or DAC cables (about 10-20 times higher). Might not matter a lot if you are just using this at home, but it is worth noting. This matters a lot for things like storage usage.
8 hours ago, PenguinMaster said:Is there any reason the Dream Machine Pro would need to be connected through 10G rather than just 1G?
It depends on where the routing is done. Are all machines on the same network? If they are then it doesn't really matter.
If for example your server and your PCs are on two different networks and your UDP-Pro is doing the routing, then you will be limited to 1Gbps if that's your connection to the UDP-Pro.
8 hours ago, PenguinMaster said:My other question was about these 10Gb SFP+ to RJ45 adapters. I need these to connect a few desktops to my Ubiquiti Switch Aggregation.
Is there any difference between these? Are any brands better than others?
The brand doesn't really matter. What does smatter however is the fact that some of those modules you linked support multiple speed settings, while others don't.
For example the first FS module you linked and the QSFPTEK module supports 10/5/2.5/1 Gbps rates.
Both the H!Fiber and FLYPRO ONLY support 10/1Gbps rates.
In other words, if you are planning on connecting some 2.5Gbps device then you need to get the FS module or QSFPTEK module. The H!Fiber and FLYPRO will only run at 1Gbps or 10Gbps, not 2.5Gbps or 5Gbps.
The difference between the normal and industrial variant of the FS-module is that the industrial one can handle higher and lower temperatures. It won't be useful for your home network unless you for some reason has the switch mounted outside, or inside your oven.
