First build! looking for recommendations/compatibility checks.
Budget (including currency): 550$USD
Country: Murica
Games, programs or workloads that it will be used for: Minecraft, Roblox, Terraria, Rocket League, Valorant, very light video editing
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): My friend made this list for me, I have checked it and agree with it. https://pcpartpicker.com/list/ThbcH2
I will probably get a 1060 when I have a bit more in the bank.
EDIT: I have monitors, adapters, peripherals, everything. I previously had an hp pavillion (intel integraded graphics 640, 6gb ram, i5-7300u, 1tb hdd
If you have to go new, this is basically you're only option.
That said, you really should be looking at used parts for something in this budget. You should be able to get a system with a 1060 and an i5 8400 for this price range, maybe even a 1070. Look on the used market around you to see what's there.
