Color Accurate monitor buying help
Solved by Stahlmann,
Get a >$300 Nano-IPS monitor and the also get an i1Display Pro or ColorMunki Display to calibrate it yourself. Results will be better than any factory calibration $500 will bring you.
Dell S2721DGF, LG 27GL850-B, LG 27GN850-B regularly sell for under $300.
If you only want 60Hz because you don't game on it, then get a 4K option like the LG 27UP600-W, the LG 27UP650-W if you need HDR support, and the LG 27UP850-W if you need USB-C power delivery.
