Monitor Advice: AOC 24G2U Vs BenQ Mobiuz EX2510
Kennymclay
I've recently put together my first PC build and am now onto the stage of getting my peripherals.
My GPU is a Nvidia Founders Edition 3070 Ti.
The two options I've come up with are an AOC 24G2U and the BenQ Mobiuz EX2510. I'll mainly use the PC for a mixture of Video editing and Gaming.
I understand I should be getting a far better monitor, however I went a bit over budget with the PC build and at this point my budget is about £220, and I plan to upgrade in the next year.
Any opinions appreciated
DisplayNinja has tested both, and gave the AOC the title of best budget gaming monitor. So. That one.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
The AOC offers better value. The BenQ is slightly faster but also more expensive.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
The AOC has been fully reviewed and does well in them.
its primary drawbacks are black uniformity, which isnt uncommon in LCDs anyway, and its resolution.
Beyond that however it has exceptional out of the box calibration for a budget monitor, and good contrast for an IPS.
Added bonus is it has BFI (MBR), while u cant use it with Variable refresh, if you choose to use it, it has some amount of finer control to change pulse width, increasing the effect of BFI (clearer moving image) at the expense of more obvious moving image doubling.
https://www.rtings.com/monitor/reviews/aoc/24g2
its popularity increased its retail price however if u can get it closer to its original release price it is certainly one of the best, if no the best, budget monitors you can get.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
