Home IP from not home
10 minutes ago, Jimmymd00 said:Thanks for your message Would a router on a stick be necessary or would a second mobile do the same? I'm going on holiday and want to use websites/services that validate user by ip
Websites won’t be an issue as far as I know, but apps can check to see if your phone is connected to a VPN (they can’t glean any actual info, but they can ask the phone “are you connected to a VPN? IF yes, I will not work” type thing. But a website I don’t think would know, theoretically the browser may be able to ask that, but I don’t think that would get passed back go the website.
Another phone won’t work unless it explicitly supports Wifi routing which you would need to figure out how to even set up. I’m not saying it’s not possible, I bet some android ROM has this built in, but you would need to set up routing on the “router” phone so it routes traffic from the SSID it would be broadcasting.
TLDR; it’s likely not impossible, but your getting into the realm of beet niche use case and your goog to have to google/forum post your way to victory…
Best bet is get a raspberry pi and set it up as a VPN router, but this will also be a rather advanced setup and you will want to test it all at a friends house beforehand to make sure it just automatically works etc. Again, it’s entirely possible, I have done it, but it does take some learning, patience, and time
