Please Need Some Help Regarding Mining Crypto.
According to Best Mining GPUs Benchmarked and Ranked (Tom's Hardware), the GTX 1060 currently has the fastest ROI based on price, energy use and hash rate. The price they found was $300 a piece.
£25,000 translates to roughly $32,775. Let's assume we can buy GPUs for $30k, the rest is needed for PSUs, motherboards and so on (I expect this is overly optimistic and you'd have to spend more on additional hardware). This means we can buy 100 GTX 1060. Each 1060 should have a hash rate of 25 MH/s for ETH, while using 90W. So let's enter $30K, 100x 25 MH/s and 100x 90W into the ROI calculator.
According to Average Cost of Electricity per kWh in the UK 2022, the price per kWh in 2022 is expected to be somewhere above 26p/kWh for most regions. Let's go with 26p and convert that to 0.34 $/kWh. We spend the remaining $2,775 on other hardware and assume it uses only 1 kW (opposed to the 9kW used by the GPUs).
With these numbers, the likely outcome would be >4,000 days or 11 years to break even. This means 11 years until you've got the money back you spent on hardware, before you see any profits come in. This assumes ETH stays profitable during this time, the difficulty stays at a level where a GTX 1060 can realistically be used to mine, and none of your hardware breaks and needs to be replaced.
