semi budget case fan options
Ghosted Muzik
so im running an amazon special case, it came with 6 120mm rgb fans but no way to control fan speed, it can fit 5 140mm and a 120mm, currently its setup as 5 intake 1 exhaust,
what would be a good budget setup that can also be controlled by the pc?
100$ usd budget
would like rgb but not 100% needed
and should i leave my intake and exhaust config alone or change it?IMG_20220210_175029882_HDR.thumb.jpg.3a92a2d2d0ff4faa14fa66028c2ea989.jpg
3 minutes ago, oliver1munkholm said:
Can you not control the fan speeds in your BIOS?
they dont connect to mobo except for an argb header and that wont even register on any software
maybe check out corsairs fans, pretty sure they have an app for controlling rgb and speeds if you get the controller module as well
Any fans that will connect up to the motherboard or some type of fan controller (like old style DVD bay controllers with knobs to control fan speed) will give you that control you're looking for.
My personal recommendation would be to get Noctua fans, or you can even get a 5 pack of Arctic fans on Amazon for ~$25. Arctic has a PST version of their fans that daisy chain for simplicity. But there's always Y splitters and hubs if your motherboard doesn't have enough fan headers.
As for your fan config, I'd swap the top rear to exhaust. You don't need that much intake, especially on a Ryzen stock cooler. Hell you could even ditch the front top fan altogether and it'd be fine.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
