is there A good cpu cooler for the Ryzen 5800X for under 55$ in sweden
Solved by GuiltySpark_,
1 hour ago, NerdyGoose said:
right now thinking of buying a noctua NH-U12 redux
If that's the best you can do, do that. I do not think its good enough to fully give the 5800x the headroom it needs to utilize PBO but at the least, it should keep it from throttling at stock, assuming proper airflow. Its a high end chip and doesn't deserve a cheap, low end cooler. (Noctua's aren't cheap, however the U12 Redux isn't a higher end model)
