Is WiFi A (1st gen WiFi) able to connect to WiFi AC or AX network?
Chiyawa
Like the title suggest, can the 1st gen WiFi (A) connect to WiFi 5 (AC) or 6 (AX) hotspot?
Regards,
Chiyawa
I have ASD (Autism Spectrum Disorder). More info: https://en.wikipedia.org/wiki/Autism_spectrum
I apologies if my comments or post offends you in any way, or if my rage got a little too far. I'll try my best to make my post as non-offensive as much as possible.
Some AC router still have 802.11a support, but most Wifi 6 device pretty much drop it dead.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
I am human. I'm scared of the dark, and I get toothaches. My name is Frill. Don't pretend not to see me. I was born from the two of you.
802.11A requires whole SSID to drop operating mode to A/Legacy. Hence why most of AC/AX networks won't be configured to allow it by default and just recommend running a separate 802.11N network for those devices.
17 hours ago, SorryClaire said:
Snip
17 hours ago, Levent said:
Snip
I see.
I actually found an old laptop that support a, b and g WiFi. Thought it can utilised AC/AX networks since I only set my router to use 5GHz WiFi. Now I need to open 2.4GHz WiFi for it.
