GPU sag concern
JurajD
Greetings dear fellows. I have a worry that I would like you to shed some light upon. I have been running with an msi rtx 2060 ventus oc for about 2 years now, and have since recently upon cleaning discovered it had picked up a decent sag. I have inspected both the pcie slot and the gpu and found that the gpu socket itself had become the culprit with its socket appearing ever so slightly bent. My question is if I should be concerned about this since a gpu upgrade seems quite a long ways off.
P.s. The big cooler while horribly tedious to work around makes me feel like a big man that can't afford a big man's gpu. Thank you in advance :)
Wouldn't be too concerned. Card doesn't seem that beefy given the fin stack and heat pipes. The weight of the cable isn't helping though. Plenty of options for a fix though.
Main RIg Corsair Air 540, I7 9900k, ASUS ROG Maximus XI Hero, G.Skill Ripjaws 3600 32GB, 3090FE, EVGA 1000G5, Acer Nitro XZ3 2560 x 1440@240hz
My old GTX 580 had some mean sag to it.. go buy yourself a slurpee and when you are done rinse the straw out and cut it to size. I used a McDonalds straw.. girthy.. With my 3070 and 980 I just let them dangle and they don't need extra support.
If you want to get extra fancy you could use a machine screw and an hdd isolating pad and affix them to the straw like I did. But I get bored and do stuff like that not sure why..
AMD R9 5900X | Thermalright Aqua Elite 360, 3x TL-B12, 2x TL-K12
Asus Crosshair VIII Dark Hero | 32GB G.Skill Trident Z @ 3733C14
Zotac 4070 Ti Trinity OC @ 3045/1495 | WD SN850, SN850X
Seasonic Vertex GX-1000 | Fractal Torrent Compact, 2x TL-B14
honestly i have seen way worse,  it should probably be fine...
However,  fret not, Jayz-daddy has something to get your gpu off the viagra (his words lol)
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
Yes, you should be concern. It's not really a hard fix, just put something to hold GPU. Get creative.
Thank you all for your replies. I have ordered a brace of sorts as a temporary fix. I have a follow up question, since im looking to snag a gpu somewhere soon, should I be worried about this happening again or can I safely believe the problem lies on my current gpu and not the pcie slot.
The slot will be fine. I had an MSI Ventus 2080 and that sagged just like yours is doing. Got a 3080 FE and no sag whatsoever, FE cards just don't seem to sag. So the slot was fine, it'll be the card.
Most motherboards have some kind of reinforcement around the PCIe slot to allow for this. Your GPU isn’t that heavy, so don’t worry too much about it.
CPU i7 14700K | CPU Cooler Noctua NH-U12A | Motherboard MSI Pro Z690-A | GPU Zotac Airo RTX 4080 | RAM 32 GB GSkill Ripjaws V 4400
Mhz |
 Monitor Alienware AW2721D / Gigabyte M28U | PSU ASUS ROG Strix 850G
