My Corsair K70 RGB + coffee = Death of a legend...?
CGurrell
Hello all,
Today I look to be saying goodbye to my Corsair K70 RGB with Brown switches. It's my own fault, I was getting my second coffee of the day ready for work at home and spilt it all over my cheap work keyboard (RIP Random membrane KB too). Unluckily for me, my K70 was behind that keyboard and took some splash damage.
I immediately tried to dry her out, followed by frantically opening her up (not the first time a drinks related incident has happened to this keyboard) and cleaning anything I could see with Isopropyl Alcohol. After that, I left her alone for a few hours whilst I finished my work day.
I'm back with her now, plugged her into my old laptop that I keep around for troubleshooting purposes, and she starts going beserk. Before I know it, my display is upside down and at 1600x zoom. Panic ensures and I unplug her. After a little more cleaning, I plugged her back in again, and to my surprise things seem normal, at first...
I open up a keyboard tester and immediately there's an issue. Shift is not only being pressed, but constantly pressed and depressed. I'm not sure which switch key it is, but I would assume the right one given that the switch has a coffee brown hue to it now.
Sadly, this is where I think her journey is coming to an end. I've had her for nearly 5 years, and she was always good to me, giving me satisfying typing and gaming experiences right to the end.
Unless anybody here can help me, I think her time has come. RIP K70 RGB, you will be sorely missed...
Current System - Intel Core i7-3770k @ 4.5GHz - 16GB Corsair Vengeance DDR3-1600 - Corsair H110i GT - 2x EVGA GTX 970 FTW+ in SLI - XFX Pro Series Black Edition 1250W - Samsung 840 EVO 128GB Boot SSD - WD Green 2TB Mass Storage HDD - Fractal Design Define S Windowed Edition with Green LED Lighting provided by 2 Bitfenix Spectre PRO 140mm fans, and 2 Corsair SP140 Green LED fans - Samsung U28D590D 4K Main Monitor with BenQ GW2265 1080p Side Monitor
As someone who had one briefly, I can safely say that it's a mixed blessing; there are much nicer boards out there 😉
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
I get you, just had it for so long that it's almost like losing a friend at this point
Dishwasher.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2
Ryzen 7 5800x - XFX RX6600 - Asus STRIX B550i - 32GB DDR4-3200CL14 - Corsair SF750 - Lian Li O11 Mini - EK 360 AIO - Asus PG348Q
If you have the tools you could maybe desolder the switch and take it apart and clean it or replace it fully but it might be easier to just replace the keyboard entirely.
If you can open up the keyboard to the PCB level, you can use a multimeter to figure out which key(s) are acting up and with a little luck you can clean the pins on the underside and it's fixed. Worst case scenario it's a deeper issue, inside the switches itself. Some alcohol on a straw and pressing the switch a couple times could get rid of an issue on the inside, or more work might need to be done.
It all depends on how deep the issue lies with this keyboard.
It's highly likely salvageable, but may require quite a bit of work to get fully operational again.
27 minutes ago, rickeo said:
Dishwasher.
If you're recommending this based on the LinusTechTips video from 2 years ago, keep in mind recently in the "Fixing my wife's keyboard for $1 video" Colin mentioned some of the dishwasher keyboard died. Likely due to corrosion, possible by salt which was added to the water by the dishwasher, possibly just due to the water getting in places that can't dry on their own.
I wasn't, actually. Its just been something I've seen people do for years and have success, especially if the alternative is the trash bin.
It is fine to do with a clean dishwasher, no additives, preferably deminiralized water and if you open the keyboard afterwards and really let it dry for a long long time moving it around often.
I've done it that way quite often and most are still going strong. But it's basically a last resort or a idc about these keyboards option.
Thanks for the suggestions everyone!
In a weird twist, I did nothing with the keyboard, had a hunch to try it this morning, and it seems to be working as normal again 😄 I'm probably still going to look at replacements as I don't really trust it to last much longer given the damage liquid can cause, but she lives!!!!
I spilled a glass of water on my K70 lux rgb years ago, it continued working perfectly for multiple years after the incident, if your coffee had sticky sugar and stuff in it that might be the cause.
But k70's are old and relatively cheap now, i'd get a apex pro tkl if i needed a new keyboard.
System Specs: AMD 5950x PBO-AutoNoctua DH-15 Black | Gigabyte x570 MasterEVGA 3080FTW3 Ultra | (2x16gb) G.Skill Royal 3600mhz CL18 | Corsair 5000D Airflow (Black) Samsung 980 Pro 2TB & Firecuda 520 1TB & Crucial MX500 2tb850W Corsair RMX | 2 Noctua A14 CPU, 6 Noctua A12x25 Intake, 3x Noctua F12 Top Exhaust, 1x Noctua A12x25 Back Exhaust
Monitors: (Main) LG Ultragear 34" 2k Ultrawide 144hz IPS '34GP83A-B' (Side) Acer Predator 27" 2k 144hz TN 'Abmiprz'
Peripherals: Corsair K100 OPX | Logitech G502 Lightspeed | Corsair Virtuoso SE | Audioengine A2+
