Please help me build the perfect PC (money is not a concern)
Bozantium
I need a highly skilled computer builder to help me to build the perfect computer. Stuff like dual RTX 3090 Founders Edition, 64 threads, stuff like that
You can give 100000USD? If yes, buy a Dual AMD Epyc 64-core and give it 4 3090s Hall Of Fame. Then you will have a very very good computer. But when you think realisticly, why would you buy that? What will you use? Maybe you need higher clock speed than more cores.
1 hour ago, Somerandomtechyboi said:
Use the subforum template
Country?
Uses?
Overclocking?
And yeah, give us the info, we don't know.
1 minute ago, aaradorn said:
If money is not an issue just buy a supercomputer from China/ US or Nasa and be done with it.
Yeah, you will have very good performance
*BTW are you Elon Musk, so money is not a problem?
Ah yes
Sped boi computer
Though for something more realistic youd prob go for a 12900k + 32-64gb ddr4
Just now, Somerandomtechyboi said:
Ah yes
Sped boi computer
I would wait for the Ryzen 6000 Series, but I don't know when he needs the computer
Thanks, everyone. “Money is no object” was more hyperbole than anything. I have between $10-$15,000 to spend on a good rig. I already have the monitor.
side note: if anyone would like to help me fix my current computer please let me know. It should be way faster than it is.
Is this your current computer setup?
Yes
2 hours ago, dilpickle said:
You still haven't told us what you want to do with this PC.
Gaming.
Yes
Country?
Uses?
Overclocking?
Sorry. First time here
1 minute ago, Bozantium said:
Yes
can push reach 50% more performance from all of it with your budget
So a 12900k, 32-64 GB of fast memory and a 3090 ? (Though I keep hearing rumors about a 3090ti so that might be released at some point)
Some gen4 NVME storage aswell for good measure.
Some of the parts have supply issues. Also upgrade to Windows 11. Everything else from existing system.
PCPartPicker Part List
CPU: Intel Core i9-12900K 3.2 GHz 16-Core Processor  ($618.77 @ Newegg)
CPU Cooler: ARCTIC Liquid Freezer II 360 A-RGB 48.8 CFM Liquid CPU Cooler  ($131.99 @ Amazon)
Motherboard: Asus ROG MAXIMUS Z690 HERO ATX LGA1700 Motherboard  ($599.99 @ Amazon)
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory  ($490.00)
Storage: Kingston KC3000 4.096 TB M.2-2280 NVME Solid State Drive  ($1082.09 @ Amazon)
Video Card: Asus GeForce RTX 3080 Ti 12 GB ROG STRIX GAMING OC Video Card  ($2100.00)
Total: $5022.84
Generated by PCPartPicker 2021-12-16 10:14 EST-0500
That would be excellent. I’m still having problems with my current computer and can’t fix it. The mbr is corrupted, I can’t perform a system restore, it takes forever to boot, etc. When XMP I is on and is set to 5 GHz I can actually get 5.4 GHz. But then I go to run resident evil 2 and I can’t get passed high settings. I’m so confused. My plan was to give this computer to my wife and buy myself a new one but I don’t want to give her a crappy computer.
Total: $5022.84
Thank you for the information
1 minute ago, ahmad13610 said:
Nooo! Not 11900K!
It really is pointless. Even 10850K and 10900k are faster. Not to mention 12900K.
I edit my posts more often than not
Build wife an entirely new system. What does she do on her system?
We game together but her laptop is no more
4 minutes ago, Tan3l6 said:
Nooo! Not 11900K!
learn from broken what he did, simple solve is best way
why not give him the build up pc. even he have a lot of budget
worth or not worth is pointess in this case
Maybe get a new drive for your Wife and install a fresh OS on there. That would take care of the MBR issue.
XMP is for memory so I'm wondering where the 5GHz number is from since that is the CPU frequency not memory. I guess it's lumped together as one setting on Intel boards ?
When you say you can't get past high settings, do you mean it crashes or does it just run poorly ?
43 minutes ago, Bozantium said:
Gaming.
Here you go. You can add another video card if you want to do 3090 SLI and you can go with whatever mobo you like. But other than that this is literally the best Gaming PC you can build right now.
You probably want to go with a custom water loop too.
CPU Cooler: Corsair iCUE H170i ELITE LCD 82.9 CFM Liquid CPU Cooler  ($309.99 @ Corsair)
Motherboard: Gigabyte Z690 AORUS XTREME EATX LGA1700 Motherboard  ($899.99 @ Newegg)
Memory: Corsair Vengeance 64 GB (2 x 32 GB) DDR5-4400 CL36 Memory
Video Card: EVGA GeForce RTX 3090 24 GB K|NGP|N HYBRID GAMING Video Card
Case: Corsair 1000D ATX Full Tower Case  ($514.99 @ Walmart)
Power Supply: Corsair AXi 1600 W 80+ Titanium Certified Fully Modular ATX Power Supply  ($609.99 @ Corsair)
Operating System: Microsoft Windows 10 Pro Full 32/64-bit  ($199.00 @ B&H)
Total: $7481.09
Generated by PCPartPicker 2021-12-16 10:27 EST-0500
