Budget (including currency): Around $1,000 AUD
Country: Australia
Games, programs or workloads that it will be used for: Literally any game I want to play while running Discord, Youtube
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Buying from Centrecom
CPU - 5 5600G
Motherboard - B550-A PRO
GPU - RX 6600 V2
RAM - G.Skill Ripjaws V 16GB (2x8GB)
SSD - Kingston SNV2S
PSU - GP-P650G 650W 80+Gold
Case - Antec AX61
And a monitor
Hey everyone, this is my first time building a PC for gaming and I don't know if these components are good together and if they fit. Also can you suggest other components as you see fit? I don't really understand all this PC requirements and specifications. I am also new to PC gaming so I would also like tips on about everything related to PC gaming, thanks. Also I think there are 4 pre-installed fans on the case and a Wraith Stealth cooler with the CPU. I haven't chosen a monitor yet and I want a 1080p 144 Hz monitor.
edit: I also want to go with air cooling and not liquid cooling
Country: Australia
CPU - 5 5600G
GPU - RX 6600 V2
Case - Antec AX61
And a monitor
I highly recommend getting the Ryzen 5 7600x
Country: Australia
CPU - 5 5600G
GPU - RX 6600 V2
Case - Antec AX61
And a monitor
also go on the website called PC part picker.com because that website will be able to tell you if they are compatable
Country: Australia
CPU - 5 5600G
GPU - RX 6600 V2
Case - Antec AX61
And a monitor
also you are going to need  cpu cooler because you don't want it to overheat
Literally no need for a APU if you have a dGPU anyway, here is the best I could configure for gaming for that price:
https://au.pcpartpicker.com/list/xDxPrv
If a post resolved/answered your question, please consider marking it as the solution. If multiple answers solved your question, mark the best one as answer.
@anirudthelinuxwIzard do i need any extra coolers?
sooooo...
Original: $973
CPU – AMD Ryzen 5 5600G
Motherboard – MSI B550-A PRO
GPU – Asus Dual Radeon RX 6600 V2
RAM – G.Skill Ripjaws V 2 x 8GB
Case – Antec AX61 ELITE
SSD – PNY Cs2241 M.2 NVMe
PSU – Gigabyte GP-P650G 650W
or
1: $924
CPU – AMD Ryzen 5 5500
GPU - Asus Dual Radeon RX 6600 V2
Motherboard - Gigabyte B550M DS3H
RAM - Corsair Vengeance LPX 16GB DDR4-3200
Case - Fractal Design Focus 2 ATX RGB White
PSU - Corsair CV750 Gold+
or
2: $1,183
CPU – AMD Ryzen 5 7600X
 CPU Cooler – Thermalright Phamton Spirit 120 SE
Which one?
I would go for 2, just do not go with the b550m because 7600x doesn't fit in AM4 socket. Go with a B650M PG RIPTIDE motherboard instead + whatever 16GB DDR5 kit you want.
also for cooler go with phantom spirit 120 EVO instead
