Most garish Socket 1150 air cooler?
Radium_Angel
I have a plain grey(ish/black) case.
I want to liven it up a bit. It has a 4pin PWN header for the CPU cooler, currently using stock intel cooler on Core i5-4430.
Need something loud (colour-wise, not sound) that isn't an AIO (not ready to fool with that yet)
Any suggestions? It's not a gaming box, so if the cooling capability is a bit naff, it's okay.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
Get any Noctua cooler for the prestige poop brown color.
Okay but really - Cooler Master has variants of the Hyper 212 that has static LEDs, and the RGB variant has a Molex power connector if you don't have an ARGB header.
It's entirely possible that I misinterpreted/misread your topic and/or question. This happens more often than I care to admit. Apologies in advance.
珠江 (Pearl River): CPU: Intel i7-12700K (8p4e/20t); Motherboard: ASUS TUF Gaming Plus Z690 WiFi; RAM: G.Skill TridentZ RGB 32GB (2x16GB) DDR4 @3200MHz CL16; Cooling Solution: NZXT Kraken Z53 240mm AIO, w/ 2x Lian Li ST120 RGB Fans; GPU: EVGA Nvidia GeForce RTX 3080 10GB FTW3 Ultra; Storage: Samsung 980 Pro, 1TB; Samsung 970 EVO, 1TB; Crucial MX500, 2TB; PSU: Corsair RM850x; Case: Lian Li Lancool II Mesh RGB, Black; Display(s): Primary: ASUS ROG Swift PG279QM (1440p 27" 240 Hz); Secondary: Acer Predator XB1 XB241H bmipr (1080p 24" 144 Hz, 165 Hz OC); Case Fans: 1x Lian Li ST120 RGB Fan, 3x stock RGB fans; Capture Card: Elgato HD60 Pro
翻生 (Resurrection): CPU: 2x Intel Xeon E5-2620 v2; Motherboard: ASUS Z9PR-D12 (C602 chipset) SSI-EEB; RAM: Crucial 32GB (8x4GB) DDR3 ECC RAM; Cooling Solution: 2x Cooler Master Hyper 212 EVO; GPU: ASRock Intel ARC A380 Challenger ITX; StorageCrucial MX500, 500GB; PSU: Super Flower Leadex III 750W; Case: Phanteks Enthoo Pro; Expansion Card: TP-Link Archer T4E AC1200 PCIe Wi-Fi Adapter Display(s): Dell P2214HB (1080p 22" 60 Hz)
壯麗 (Glorious): Mainboard: Framework Mainboard w/ Intel Core i5-1135G7; RAM: G.Skill Ripjaws 32GB (2x16GB) DDR4 SODIMM @3200MHz CL22; eGPU: Razer Core X eGPU Enclosure w/ (between GPUs at the moment); Storage: Samsung 970 EVO Plus, 1TB; Display(s): Internal Display: Framework Display; External Display: Acer (unknown model) (1080p, 21" 75 Hz)
id cooling /thermlright?
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
 Hold my beer...
https://www.newegg.com/icesleet-x9/p/13C-00RE-00001?Item=9SIAT5SD3F3178
..mic drop..
I was so excited to post that I didn't even look at the compatibility. Too late, its too good, it stays.
edit again..
They make a compatible one!
https://www.newegg.com/icesleet-x7/p/13C-00RE-00002
3 hours ago, rickeo said:
 Hold my beer...
..mic drop..
edit again..
I love it!
Thank you, just what I was looking for. You, Good Sir, win the day!
14 minutes ago, Radium_Angel said:
I love it!
Credit to @emosunfor linking this in a build thread a while back. Stuck out in my mind when you said "garish" LOL
they make fans too for the case...odd looking but i guess for the right build it could be money? every now and then i see a build around looks over everything els...
I saw they made case fans too, but I think that would be overkill. Garish colours work, if you don't overdo it.
