Need help with upgrade
Chouffeke
Go to solution Solved by Somerandomtechyboi,
Just overclock the cpu, might aswell not let the cpu and board have wasted potential
Max safe volt according to intel spec is 1.52v vcore though keep temps under 85c
Run as high of a vcore your cooler will allow and then work on cpu freq, though i suggest watching overclocking tutorials because im garbage at explaining
Edit: noooooo my 69 community answers thingy ;-;  guess ill have to wait till 169 ;-;
Budget (including currency): €300
Country: Belgium
Games, programs or workloads that it will be used for: Halo Infinite, Lost Ark, GW2, nothing to heavy
Momentarily I'm running a MSI GTX1070 i5 - 6600K, Gigabyte Z170-HD3 motherboard, 16gb RAM, CX650 Power Supply. I have no clue which component I should upgrade within my budget and need help. Budget isn't fixed to  €300.
What's the real budget then?
What are your upgrade goals?
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
Country: Belgium
If you're not playing anything too heavy, that is a perfect machine for it.
All SSD's I assume?
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
My budget is max 400, but ideally around 300. I'm noticing my CPU running at 100% at times and I'm not knowledgable enough to know if just putting in a new CPU is the best idea.
My goal is mostly thinking about being able to run games in the future and maybe a bit smoother at the moment. As in: should I think about upgrading maybe the motherboard and CPU in the near future while I wait for GPU prices to become a bit more reasonable? Or is that just a stupid idea and wait a few years to get a complete new build?
Any advice and opinions are welcome.
I've got a m.2 ssd (1tb) and a sata ssd (256gb) which I initially used when I built it. Also a 1tb hdd just for files.
All SSD's I assume?
I posted without replying to you guys directly. My answers are in the previous message.
CPU is overclocked to 4,2 at 1.25v because some guide recommended it. The fact you said intel says max safe volt is 1,52 surprised me so I'll try to overclock to a higher frequency and stresstest myself later. Thanks for the advice!
Lol 4.2 is childs play
Tbh absolute max "safe" volt according to my rule of thumb is ~1.6v as the highest volts ive seen on 14nm is 1.9v which is deathzone
Tbh your cooler may even be able to handle 1.6v considering that i5 is a 4c 4t cpu so shouldnt generate much heat anyways
It took me way too long to decypher what you actually said. Makes me realise I know nothing at all about computers. ^^'
I'll definitely look up more guides and try to OC quite a bit more then.
Thanks again and I'll consider my question answered. Cheers!
Also make sure to watch multiple guides and take the highest voltage reccomendations out of all of them cause most guides are for beginners so they use baby voltages that are not even close to the absolute max safe aka ruining potential performance that can be gained
you may also wanna add a +0.05v offset aswell to the reccomedation, if you wanna be risky then you could do +0.1v but that could easily land you in a rather unsafe voltage zone
