5.1 vs 7.1 sorrund sound
patriciadiaz1919
I keep seeing 5.1 moslty is moslty used for everthing and rare see 7.1
What are 7.1 audio are used for and are they worthless?
How do they work if there no 5.1 audio will all the speacker sound in the same time or only sound two of them in stereo mode and will the back stereos next to me will it still sound with out a 5.1 show?
What cables do I need as parents still use the old 90 rca and what the best do I need for lowless,hi rez,flac.
I am gonna get Denon S760H as good price and newest version.
There are modes on the reciever to change this. Normally you can play it as stero, 4 speaker stereo(so the side play the same as the fronts), dolby prologic, so it tries to convert stero to surroundsound, and other modes.
The mode you want depends on what your listening to and how you want it to sound.
What are you playing audio from? Normally HDMI audio is the best you can get these days, but most recievers have multiple inputs.
THe other thing to look at is how your room is layed out and where speakers would go. ALso look at things like 5.1.2, so you have height speakers instead of rear speakers, and it can often be better for atmos master tracks.
9 hours ago, InadequateComputerUser said:
The difference is 2 speakers.
In this image each red square represents a speaker. You have see the 7.1 had 2 additional front facing.
5.1-vs-7.1-Surround-Sound-Explained-and-
yesh what ever site made that needs to be fired.
5.1...7.1 or 5.1.2
5.1 is all you need for surround experience and it's more flexible for your seating location, which is why it's more popular choice but it doesn't make 7.1 useless.
7.1 divides your surround speaker from 2 to 4 giving you better positional sound and filling ambient sound better across the room. Personally I really like 7.1 for gaming as it gives better seperation between side and back surround, and for media content it's less significant but it's still alright. I haven't tried 5.1.2 yet assuming 2 height speakers are at the middle ceiling, but I've seen more people prefer 5.1.2 over 7.1 for movies. If you're absolutely willing to install two ceiling speakers then do it.
PC spec: CPU: RYZEN 9 5950X | GPU: SAPPHIRE NITRO+ SE AMD RADEON 6900XT (Undervolt to 1045mV) | MB: MSI MAG TOMAHAWK x570 RAM: G.SKILL TRIDENT Z NEO 32GB (2x16GB) DDR4-3600 (OC to 3800 14-15-15-25) COOLING: NOCTUA NH-D15, BE QUIET! SILENT WINGS 120 & 140mm| CASE: IN-WIN 707 | 5.25" BAY: LG WH16NS60 INTERNAL BLU-RAY OPTICAL DRIVE | PSU: SEASONIC PRIME PLATINUM 1000WUPS: POWERSHIELD COMMANDER TOWER 1100VA
PERIPHERALS: KEYBOARD: CORSAIR K95 PLATINUM XT BROWN SWITCH | MOUSE: CORSAIR SABRE PRO WIRELESS | CONTROLLER: PDP AFTERGLOW WIRED CONTROLLER, DUALSENSE
DISPLAYS: LG 34GN8502x DELL S2721DGF | LG C1 48"
HT & audio stuff:  AVR: MARANTZ SR7013 | STEREO AMPLIFIER: YAMAHA AS-501 | SPEAKERS: DALI OBERON 7 & DALI ZENSOR 1 & 2x SVS-SB2000 | HEADPHONE DAC+AMP: TOPPING L30+E30 | HEADPHONE: SENNHEISER HD6XX, BOSE QUIETCOMFORT 35 II | MICROPHONE: AUDIO-TECHNICA AT9934USB | BLU-RAY PLAYER: PANASONIC UB820
having used both 7.1 and 5.1, i'm not sold on 7.1 as being worth it.  I'd sooner go 10.2 than 7.1--as i feel the 3-dimensional aspect would far outweigh 2 additional fills in the same plane.
*edit*
I guess they changed the nomenclature to "x.y.z" format.  So 10.2 is "5.2.5" now.  dumb.
  • 2 weeks later...
Is it I keep people say for music you need 7.1 to high ress or lowless flac to play better is it true vs getting 5.1 version.
If I get 5.1 get can I keep the it when I upgrade it to 7.1 like with Klipsch brand.
It's absolutely fine to get 7.1 AVR and pair it with 5.1 speakers, just make sure you set 5.1  speaker layout on settings. Then when you want to add extra two back surround (or height) speakers you simply buy two more speakers and connect to your existing AVR.
I have a 7.1 avr as not sure will the audio be effect it if  one was higher than other one as one may be 2 feet and other is 1 feet or less.
theres manual distance/ position adjustments you can do for that. or if the avr has it. a lot have a built in speaker set up like Audyssey (denon), YPAO (yamaha), MCACC (poineer), AccuEQ (onkyo)....not sure what other brands have in the way of room calibration
Although there's guideline on how to place surround speakers, you don't have to follow it accurately. They're mostly filled with ambient sound so having one slightly mislocated speaker won't hurt your surround experience.
I will add that my experience improved significantly when I moved my surrounds in my 5.1.2 setup from being on the side slightly in front of the listening position (due to space constraints / no stands) to where they actually should be. It's much more immersive now.
On 11/16/2021 at 10:21 PM, IPD said:
*edit*
Sort of a yes but no situation. 10.X means more front and surround channels. 5.X.Y means the usual 5.X channels plus Y Atmos channels. On the "larger" receivers (7.X and up) some of the channels can typically be reconfigured so it can either function as, for example, a 7.2 unit or a 5.2.2 one.
No. Most music is stereo, meaning only two channels, so a 2.0 or 2.1 setup is all you need. If you hook up 7 speakers and play stereo music only the front left and right will play, while the other 5 of them will simply not produce any sound. You can switch the receiver to an upmixing mode or "all speaker stereo" mode though. For movies, so far 5.1.X has been thoroughly enjoyable to me.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
All I have to add is to reinforce the point others have made, it all comes down to the content you're consuming and whether it supports it or not.  Atmos is a system that adapts to any configuration but that's only going to be on newer movies.  I'm not sure if streaming services offer atmos streaming because while I have a 5.1 denon/klipsch home theater I consume 99% of my content on my computer with headphones.  But I would keep that in mind.  For music it's all 2.0 and 2.1 minus a few rare multi channel recordings but that never caught on and the chances of music you like being in that format are slim.
Open-Back - Sennheiser 6xx - Focal Elex - Phillips Fidelio X3 - Harmonicdyne Zeus -  Beyerdynamic DT1990 - *HiFi-man HE400i (2017) - *Phillips shp9500 - *SoundMAGIC HP200
Semi-Open - Beyerdynamic DT880-600 - Fostex T50RP - *AKG K240 studio
Closed-Back - Rode NTH-100 - Meze 99 Neo - AKG K361-BT - Blue Microphones Lola - *Beyerdynamic DT770-80 - *Meze 99 Noir - *Blon BL-B60 *Hifiman R7dx
On-Ear - Koss KPH30iCL Grado - Koss KPH30iCL Yaxi - Koss KPH40 Yaxi
IEM - Tin HiFi T2 - MoonDrop Quarks - Tangzu Wan'er S.G - Moondrop Chu - QKZ x HBB - 7HZ Salnotes Zero
Headset Turtle Beach Stealth 700 V2 + xbox adapter - *Sennheiser Game One - *Razer Kraken Pro V2
DAC S.M.S.L SU-9
Class-D dac/amp Topping DX7 - Schiit Fulla E - Fosi Q4 - *Sybasonic SD-DAC63116
Class-D amp Topping A70
Class-A amp Emotiva A-100 - Xduoo MT-602 (hybrid tube)
Pure Tube amp Darkvoice 336SE - Little dot MKII - Nobsound Little Bear P7
Audio Interface Rode AI-1
Portable Amp Xduoo XP2-pro - *Truthear SHIO - *Fiio BTR3K BTR3Kpro
Mic Rode NT1 - *Antlion Mod Mic - *Neego Boom Mic - *Vmoda Boom Mic
Pads ZMF - Dekoni - Brainwavz - Shure - Yaxi - Grado - Wicked Cushions
Cables Hart Audio Cables - Periapt Audio Cables
Speakers Kef Q950 - Micca RB42 - Jamo S803 - Crown XLi1500 (power amp class A)
*given as gift or out of commission
