Which Monitor For 500$
SpaceJD
For your budget the MSI MAG274QRF-QD is as good as it gets.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
Refresh rate? Screen size? Do you have any other preference like the panel(TN, VA, IPS)?
On 4/5/2024 at 10:13 PM, LAwLz said:
I am getting pretty fucking sick and tired of the "watch something else" responses. It's such a cop out answer because you could say that about basically anything, and it doesn't address the actual complaints. People use it as some kind of card they pull when they can't actually respond to the criticism raised but they still feel like they need to defend some company/person. If you don't like this thread then stop reading it. See how stupid it is? It's basically like telling someone "shut the fuck up". It's not a clever responsive, it doesn't address anything said, and it is rude.
bruh switch to dark mode its at the bottom of this page
VPN Server Guide
screen size really doesnt matter to me as long as its under like 32", and preferably 144-165 if its 1440p. im not really sure about the panel.
1 minute ago, SpaceJD said:
Both pretty fine, the other ideas in mind would be Odyssey G5 by Samsung at that price range.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
I am human. I'm scared of the dark, and I get toothaches. My name is Frill. Don't pretend not to see me. I was born from the two of you.
I love my LG Ultra Gear. Had it for a couple of years now and I've only started liking it more and more. I think that choice is probably more so personal on aesthetics than anything.
My Rig: AMD Ryzen 9 5900X 12-Core 3.7 GHz Socket AM4 105W || NZXT - Kraken X62 Liquid CPU Cooler || MSI MAG X570 TOMAHAWK WIFI AM4 AMD X570 SATA 6Gb/s ATX AMD Motherboard || CORSAIR Vengeance LPX 32GB (2 x 16GB) 288-Pin DDR4 SDRAM DDR4 3600 (PC4 28800) || SAMSUNG 980 PRO M.2 2280 1TB PCI-Express Gen 4.0 x4 || SAMSUNG 970 EVO PLUS M.2 2280 500GB PCIe Gen 3.0 x4 || Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive || MSI RTX 3080 GAMING Z TRIO 10G LHR || Fractal Design Meshify 2 Black ATX Flexible Dark Tinted Tempered Glass Window || Seasonic FOCUS GX-850, 850W 80+ Gold, Full-Modular || Microsoft - Windows 10 Pro OEM 64-bit || Logitech - G502 Proteus Core Wireless Optical Mouse || Input Club K-Type w/ Ajazz Kiwi Switches
do you know if the quantom dot tech on the msi is worth it compared to the non qd version?
the QD is the best monitor available for under 700usd, the non-qd loses alot of its advantages.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
Apart from Samsung monitors generally not being that good and having numerous firmware issues, the G5 series mostly consists of "even-slower-than-average" VA monitors. I'd strongly advice against them.
