B460M Will 1st PCIE x16 operate at x8 ?
Solved by mariushm,
Top pci-e x16 slot receives pci-e lanes from CPU.
The pci-e x1 slots and the bottom pci-e x16 slot ( electrically maximum x4) receive pci-e lanes from the chipset.
So you can plug the wireless adapter in either the pci-e x1 slots or in the pci-e x16 slot at the bottom and it will not affect the top pci-e x16 slot.
// Interesting how the motherboard model is B460M making you think it uses the B460 chipset, but all the information on page mentioned H470 chipset. Anyway, it's not like there's major differences between them, just an observation.
