iMac comparable monitor
wall03
I am currently looking for a monitor that is comparable in specs and performance to the display on the iMac 24" at less or the same as $800 USD. Why? My relative (photographer) is shopping for an iMac or Mac Mini and they would rather have the Mac Mini with an external monitor (which would have to meet the specs of an iMac) because of the modularity and potential savings. Could you please aid me in the quest of finding a monitor?
For help, here are some of the specs of the iMac 24" monitor (according to Apple):
-P3 color gamut
-4480 x 2520 resolution (The resolution doesn't matter quite as much but would be preferable at 1440p)
Thanks!
please quote me or tag me @wall03 so i can see your response
motherboard buying guide      psu buying guide      pc building guide     privacy guide
ltt meme thread
folding at home stats
pc:
RAM: 16GB DDR4-3200 CL-16
CPU: AMD Ryzen 5 3600 @ 3.6GHz
SSD: 256GB SP
GPU: Radeon RX 570 8GB OC
OS: Windows 10
Status: Main PC
Cinebench R23 score: 9097 (multi) 1236 (single)
don't some things look better when they are lowercase?
-wall03
hello dark mode users
goodbye light mode users
the one i'd go with is the pd2720u, it's a bit worse than the ezio and nec models but alot cheaper
https://www.bhphotovideo.com/c/product/1456435-REG/benq_pd2720u_27_4k_uhd.html/specs
since you are in NY u can go to bh to see it physically
the current ezio and nec models are cg279x and pa271q, those are over 800bucks and just for spec reference
the cheaper benq ezio dell nec models if you wanna buy used
ezio cs2731 nec pa272w, benq sw270c and dell up2718q
again that's just the ones i know of,  it really depends on what inputs you need, i only use the pa272w for certain games. If my monitor broke today i'd get the pd2720u
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
