3080ti partner model reviews
krakek
I have not seen any good MSI gaming x trio 3080ti reviews, only ones for the 3080 version.
What is the general opinion on that model?
Current system. CPU: AMD Ryzen 7 5800X; MoBo: Gigabyte X570S Aorus Master; RAM: 2x Crucial Ballistix MAX 2x8 GB (BLM2K8G40C18U4B); GPU: RX 6900 XT Gigabyte Aorus Master; case: Fractal Design Meshify-2; Storage: Samsung 980PRO 1TB NVMe SSD + 2x Samsung 980 1TB NVMe SSD; PSU: Seasonic Focus GX-850; Cooling: Arctic Liquid Freezer II 360.
With the current graphics card market, the consensus on every model of every card is "if you can buy it, it's good enough".
MSI's gaming X trio is fine. Expect it to be relatively similar in performance and noise level to all the other 3 fan triple slot cards.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
That's the one I have!
Im very happy with it.
I use it to game on a 49" LG NanoCell TV to game, I lock my FPS at 120
No Problems with MW2019,Cold War or any BF title.
Generally I have it slightly OC'ed with the Power Limit set to 108% and the temps never go over 63c
Farcry6 also looks and performs great.
I have a 3080 ti Gaming X Trio and a Gaming X Trio 3090.
I consider them conservative so if you want an overclocker get a EVGA FTW3 Ultra or a ASUS ROG Strix. They are 450 watt cards and the MSI is a 380 watt card.
Since it is conservatives it has non of the issues that some cards have with vram temps but it does need adequate cooling.
It also does exactly the same frames as the 3090 version so if you don't need the vram you are not missing out.
Would I buy again?
I did. I got the 3090 first and was so impressed with the build quality and the vram temps that when an auto notify came up for the 3080 ti version I went for it.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
Thanks for all your comments? Amazon has not been kind on me sadly, delaying shipment multiple times for the Aorus Master I ordered, so I decided to see if an alternative brand order would make it through.
