Quad port 2.5Gbe PCI-E 2.0 (x4 or x8)
El_Digital
I'm searching for a Quad port 2.5Gbe PCI-E 2.0 (x4 or x8) card but I can't find it, only 1Gbe ones. My plan it's to have 1 or 2 of those cards in a Supermicro X8DTE motherboard. I know that there are a bunch of dual port cards, but I'm not willing to sacrifice 3 or 4 slots.
do you actually need 2.5 Gb dedicated to each client?  Or would a 2.5gb switch work?
2.5Gbe dedicated, I need to connect multiple devices/networks.
Probably your search for PCIe 2.0 constraining results, 2.5Gbe is 5 years newer than PCIe 3.0 so there's little reason to have a 2.5Gbe card that runs PCIe 2.0.
Just get 3.0 cards and run them in your 2.0 slots, checking the bandwidth checks out.
F@H
GPD Win 2
4 minutes ago, FRSHPRNCFBLR said:
RJ-45 I assume?
Yes, RJ45. Thanks for the list, I'll check them.
Thanks for clarify me. My concern now its regarding the power, since 3.0 cards need more that the slot can provide.
4 minutes ago, Zagna said:
Thanks I'll check if this is the one.
