Laptop makes beeping sound when plugging/unplugging charger
Solved by Prodigy_Smit,
2 minutes ago, Chaffy said:Perhaps reading my post in full detail would also have lead you to assume this was not a manufacturer thing, as was my thought.
I should have addressed this in my first post my bad. My best guess is that some Acer software or driver update occurred over night which cause the beep to begin.
3 minutes ago, Chaffy said:It's an Acer-specific thing I suppose.
It is an Acer specific thing although I am not sure why they would do it with a beep as opposed to having a prompt display on screen but I assume that is so that the user knows it works when the display is off or the laptop is in sleep.
