Busted Auxiliary laptop antenna cable
If it was me, I would replace the card. If you don't want to mess with replacing the antenna wire, I don't see why you couldn't get the replacement wire kit (they're pretty cheap) and instead of replacing the whole wire, just cut the end off of the new wire, a few inches from the end of the connector (so that you have plenty of spare wire on the bare end if your first attempt goes awry) and splice it together with the existing wire that is missing the connector.
You could twist them together, solder over them and wrap in electrical tape. Or use those shrink wrap tubes that shrink when you apply heat near them (such as the soldering iron). Work carefully and take your time.
You just need to work with the wire, so
put something over the laptop like tin foil, so in case the solder drips, it lands on the tin foil and not inside the laptop. Make sure unplug the laptop and remember to remove the battery before working on it as a safety precaution.
Or just twist them together (no soldering) wrap the wire in electrical tape and hope for the best. I personally would replace the card either way with something better/more reliable.
Just my opinion/idea.
