PWM fan mod problem
DigitalONE
Hello
i bought a 1.74 amp delta fan and my motherboard supports 1 amp only, so i removed the red and black wires and connected it to the molex and the yellow and blue wires to the motherboard's system fan header, the fan works and i can see the fan's speed but can't control it's speed, neither through bios or fan control software, i thought the fan is bad, so i tried another pwm fan that is less than 1 amp using the same method and it did the same thing, so i connected that fan directly to the motherboard and pwm worked fine, if i disconnect the red and black wires from the fan header pwm doesn't work, anyone knows why this is happening?my mb is H81M-S2PV rev. 1.0
It might be that since it’s not conected to the board and drawing power, the bios is confused and just both thinks it’s there and on and not at the same tine
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
Is the fan header set to use pwm? Is the fan running at max rpm with just the first two pins connected?
If the fan is not connected to the motherboard, there's no way for the system to communicate or see it.
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Fedora 38 x86_64
Secondary: AMD Ryzen 5 5600G, 16 GB 2667 MHz DDR4, Fedora 38 x86_64
Server: AMD Athlon PRO 3125GE, 32 GB 2667 MHz DDR4 ECC, TrueNAS Core 13.0-U5.1
Home Laptop: Intel Core i5-L16G7, 8 GB 4267 MHz LPDDR4x, Windows 11 Home 22H2 x86_64
Work Laptop: Intel Core i7-10510U, NVIDIA Quadro P520, 8 GB 2667 MHz DDR4, Windows 10 Pro 22H2 x86_64
this is is the mod
NF-A14 5V PWM - how to use in a PC? | Overclock.net
Edited by thrasher_565
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
thanks for your replies
i found out the cause of this issue, it's the motherboard's system header, pin 2 is responsible for +12v and speed control, i can't use that pin because of the fan's high amperage, that's why i can't control the fan, but on the cpu header pin 4 is speed control, i didn't expect that the headers are different, i've added an image from the manual
What exact fans are you using? Speed control on the Pin 2 is via DC control, not PWM.
might be able to change it in the bios but ya probably just use the cpu header
