My pc has been randomly restarting while playing various games. I have some errors warning and a critical in the event viewer at the time it happend : photos - img 1 https://prnt.sc/1s2xuab img 2 https://prnt.sc/1s2xz28. its happend while playing various games and my gpu drivers and windows is up to date. does anyone know what i can do
https://linustechtips.com/topic/1372964-help-pls/
I am not sure that PSU is reliability...
CPU:AMD Ryzen 5 5600 3.5 GHz Processor | CPU Air Cooler:Thermalright Assassin X 120 Refined SE | Motherboard:MSI B450M GAMING PLUS MATX AM4
Memory:G.Skill Ripjaws V Series 32GB (2x16GB)  DDR4-3200 | GPU:PowerColor Fighter Radeon RX 7600 8 GB Video Card
Storage #1:Silicon Power A55 512GB SSD (OS driver) | Storage #2: Silicon Power A60 1TB M.2-2280 PCIe 3.0 X4 NVMe (Anything else)
Case:Cooler Master MasterBox Q300L | Case Fan: 3x Thermalright TL-C12C (2x intake fans, 1x exhaust fan)
Power Supply:Corsair CXM (2015) 450W Bronze 80 Plus |OS:MS Windows10 (64-bit) | Monitor: ASUS VG275 27” 1080p 75 Hz FreeSync
https://linustechtips.com/topic/1372964-help-pls/#findComment-14988289
Just now, Cool_Evlo said:
How is that relevant though?
OP also screenshotted their specs and sent above.
Specs are always relevant in troubleshooting, it's why the "read before asking for help" sticky on the troubleshooting forum (where this thread will probably get moved to) says to list them. This problem is just as likely if not more to be hardware related than anything to do with Windows.
Unfortunately, @Brxdman, the screenshots only show that Windows shut down unexpectedly, they don't tell us anything about what the cause of the crash was.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1372964-help-pls/#findComment-14988298
well games crashing. knowing specs would help.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1372964-help-pls/#findComment-14988299
1 minute ago, SavageNeo said:
specs? including motherboard, psu, gpu, cpu, storage, case and cpu cooler
Ryzen 5 2600 not overclocked - stock amd cooler
Asrock b450m steel legend
16gb corsair ddr4 3000mhz
xfx rx 5600xt thicc ii not overclocked
2tb samsung 870 QVO sata ssd - 2x samsung 480gb - 1 crucial mx500 250gb
600w aerocool integrator 600w 80+ bronze psu
fractal design meshify s2 case
3x corsair ll120 fans
4x corsair  CL-8930002 rgb strips
https://linustechtips.com/topic/1372964-help-pls/#findComment-14988302
alright, saw your specs in your profile. your PSU is horrible. it is not the cause of games crashing though, but if you are going to get better gpu ,i would throw that psu to E Waste.
try other drivers? the newest arent the most stable ones. also updating bios and chipset wont hurt.
https://linustechtips.com/topic/1372964-help-pls/#findComment-14988303
also the "critical" error indicates that your pc has shutdown, mayby show what the "error" events say
https://linustechtips.com/topic/1372964-help-pls/#findComment-14988305
im planning on getting a new psu soon anyway and i used a program i saw on a youtube video called snappy driver installer and installed all the drivers there when the crashes started
https://linustechtips.com/topic/1372964-help-pls/#findComment-14988306
so oyu installed the drivers AFTER the crashes started?
also i would not use the sanppy driver thing. never heard of it. i use Driver easy. bios and chipset would not be in there though, you have to get them at your motherboard's manufacturers website
https://linustechtips.com/topic/1372964-help-pls/#findComment-14988310
https://prnt.sc/1s2zyek - https://prnt.sc/1s3005j - https://prnt.sc/1s301b7 - https://prnt.sc/1s3028e - the errors leading up to the critical
https://linustechtips.com/topic/1372964-help-pls/#findComment-14988311
yes after the crashes and ill do that from now on. i should probably also add ive ran this pc for about a year now and the issue never happend, i cant recall doing anything(updates, installs etc) it just started crashing
https://linustechtips.com/topic/1372964-help-pls/#findComment-14988313
Yeah, the errors indicate that the maximum capacity of "perdiag logger" have been achieved. you might need to google how to make it bigger.
https://linustechtips.com/topic/1372964-help-pls/#findComment-14988325
2 minutes ago, Brxdman said:
do you thing a windows re-install could solve the problem?
mayby, but that wqould be my last resort
https://linustechtips.com/topic/1372964-help-pls/#findComment-14988331
No, no, uninstall that. Just download from Asrock and AMD websites, and install drivers manually yourself.
https://linustechtips.com/topic/1372964-help-pls/#findComment-14988353
