🎈Nvidia Settings: Max Frame Rate (slider) can't chose 60fps, only 58-62 🙄
4 minutes ago, Bender Blues said:After 30+ years behind a PC, dummy here can't select 60fps.
Pulling the sider, it just won't set. I've done everything I can think of to try and micro move to 60. Nope.
* On my G502, I've turned sensitivity nearly off thinking I can land it.... no. No settings will get it there.
* Tried three surfaces.... no.
* Lets try a different mouse... no.
* OK, lets manually enter it... no. You can put a number in the box but you can't delete the first or last number, always resulting in a 3 digit number.
So stupid, even rebooted knowing I'm wasting my time.
WTF does a person do to get 60 in the box?
TY folks!
For me, pressing delete, while the cursor is behind the number worked
