Is there any cooler replacement for my GPU?
sohnnyjins
Hey guys,
I am searching for a cooler that fits my GPU. It's a PNY GTX 1050ti XLR8. Generally I'm really happy with the performance for the Games I play, so there is no reason for buying a new GPU (especially with the actual market situation). Unfortunately, the Fan is whining, even at the lowest speed (can't go under 30%), that's really annoying, and I don't want to buy a new GPU just because of that. That's the reason why I'm searching for a cooler. I don't care if it looks pleasing, if it is a mix match from some other GTX 1050ti, or an aftermarket cooler. I also looked up some arctic coolers, but they don't seem to support GTX 1050ti's.
I look forward to your suggestions :)
Just get a replacement fan. Disassemble the card, read the fan model and take picture of the broken fan (connectors, behind the fan, fan blades, everything) check ebay and and aliexpress for a replacement fan. I wouldnt get a third party cooler for a 1050ti, as its simply not worth it. Grab a tube of thermal paste while at it as well, Arctic MX4 or MX5 would be my recommendation.
looks like it'll be easy to zip tie 120mm fans on there
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
120mm would be a pain i would 90 92mm or 80mm.
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
