CPU immediately overheats to the point of emergency shutdown - what to replace first?
3 minutes ago, Rybo said:Hi everyone,
[TL;DR]
- Ryzen 7 3700x is thermal throttling/shutting off in my NZXT H1 case/cooler
- Ryzen 3 30-something-or-other worked well in the case for a while, but recently exhibited similar, though not as catastrophic issues
- Temps spike fast enough to suggest poor contact, but contact looks good
- AIO fan is running
Question: The only logical answer I can come up with is a bad pump...but would a bad pump really let the temp spike that quickly? Even with no flow, it should absorb idle loads for 10+ minutes with a slow increase in temp, right? (Note: there are no puddles of coolant anywhere near the pc, so catastrophic failure is unlikely)
[Long version]
As the subject line said, there's an obvious and substantial problem -- my Ryzen 7 3700x immediately shoots to 80 degrees in BIOS and 95 degrees in the OS (and then shuts itself down shortly thereafter). Until today I had a Ryzen 3 30-something-or-other in there as well that I noticed had very poor performance that I attributed to it being a Ryzen 3, but in hindsight it was probably the same issue (given that it had been in the case for months with no performance issues). If I were diagnosing the issue for someone else, I'd tell them they had poor contact between the cooler and the chip (the case is the NZXT H1 with the stock 120mm AIO in it). However, unless poor contact looks WAY different than I've seen in the past, I think my contact is good: a dab of paste in the center of the IHS was smushed to every corner of it. Screws were tightened evenly, etc. I can get a picture if y'all really think it's poor contact. The AIO fan is also working fine.
However, given that the Ryzen 3 that was in there was able to keep VR games (Half Life Alyx, Beat Saber, others) running fine in the recent past and is now also chugging pretty hard on Satisfactory, I don't think it's poor contact.
This set of facts is leaving me kinda stumped. Even an AIO with a dead pump should keep the thing a decent temp for a little bit, shouldn't it? I would expect immediate catastrophe from an EMPTY AIO, but mine has definitely not failed catastrophically and I can't say I've heard the telltale sign of a dry pump at any point, either.
So....what do I replace first? I guess the AIO is really the only option unless you tell me that the Ryzen 7 is too much for a 120mm AIO, even at idle.
Thank'y kindly in advance for your words of wisdom, LTT!
Have you tried to boot the computer outside of the case with a stock cooler on? This will rule out the cooler at fault.
If you are not comfortable shorting pins to boot, you may install the stock cooler and mount your motherboard to the case with side panels open.
