Corsair H100X humming louder than 10 fans combined
The Corsair H100X is my first ever liquid cooler and so far, Im not so sure about it.
I have 10 fans installed in my system and they're all running. Still, the humming sound the pump is making is way more audible than the fans.
Does anyone have experience with AiOs? Is this normal behaviour or do most AiOs not produce any humming.
Thanks in advance!
how old is the cooler?
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
3 minutes ago, whyisluistaken said:
2  days
how is the pump oriented in your case? Can you post a picture or 2?
"Black Out"
The AIO is mounted vertically but with the tubes at the top and the pump being lower than the radiators outlets.
it doesn’t sound like air being trapped inside the pump. It sounds more like a really loud hard drive
you may need to install corsair iCue and setup a pump speed profile assuming its PWM controllable or adjust the fan header its on in the BIOS to find a suitable noise level for your hearing.
"Black Out"
air might need to settle out of the pump. just give it some time
