I need help getting better Wi-Fi speeds wirelessly.
Solved by Electronics Wizardy,
7 minutes ago, Admansrs said:Is there any particular card you'd recommend? Are they pricey or is the investment worth it?
Something like this one?
They all work the same cause they have the same chipset, Id just get one with a cabled antenna.
