3080 not displaying to monitor
Solved by DarrenM0731,
On 7/30/2021 at 10:27 AM, DarrenM0731 said:I I just built my new PC but it's not wanting to display to the screen and says no signal (won't even show bios), switched back to my old card and it works perfectly. The 3080s lights and fans turn on but nothing else. So I believe it's something wrong with the 3080 connecting to my system but I was curious if anybody has the same issue and hopefully a fix. I also just updated my bios and still not working, I replaced the cable and my led indicator light is showing nothing. I tripled checked and everything is connectedSpecs:Ryzen 5 3600Asus tuf gamingx570Corsair dominator ram 2x163080 feCorsair rm850x
So I tried a bunch of stuff with no solution, still said no signal. I said screw it I'm just gonna leave it on with the no signal popping up and after like 20 mins it turned on. So my assumption is it needed time to recognize the card.
